DraftSight plotting
DraftSight plotting
DraftSight plotting
Hi
I can't print lines that are yellow. They appear as blurred lines on the paper.
Please give me a hint to correct this problem.
Johnny
RE: DraftSight plotting
If you are printing a colored print in black and white:
Look in the Print dialog box at the bottom - Additional Options - Print Style Table.
Mine is set to monochrome.ctb and prints in black and white. All lines print the same.
Also, they are located in Program Files - Dassault Systemes, Default Files, Print Styles.
Other Styles print differently and you'd have to set them for your printer.
I have tried this now, but yellow lines are still appearing blurred.
Any other suggestions, please?
What are your settings in the Additional Options?
I have - Use assigned Print Styles checked & Print Quality: Normal.
Make sure your Yellow Layer is color 2 and not 50 or 51.
Go To Options - System Options - Printing - Print Style File Location and find where your files are located.
Go To the location.
Double Click the monochrome.ctb - Table view - Color 2 - dithering-on, convert to grayscale-off.
Thank you, I will try this as soon as possible
