Pressure Let Down
Pressure Let Down
Hello all,
Is it possible to let down compressed gas from a 300barg cylinder to <1barg with a single stage regulator? Its a very low flowrate (20Nm3/hr). If I need an expensive let down skid the concept is stuffed so hopefully its a conventional operation.
Cheers,
PR
Cheers,
PR
The scientist describes what is; the engineer creates what never was.
RE: Pressure Let Down
Be careful with what temperature you want / need.
300 to 1 barg could be a significant temperature drop.
