mode participation factor
hi, I am trying to calculate mode participation factors for a frame structure. the consistent mass matrix approach is used. I got the Eigen values, vectors, checked orthogonality - all ok. for calculating the mode participation, gamma=L/M, L is the coeff vector = [transpose(phi)]*[m]*[r]. how do I calculate the vector r. I went through few books/web which says r is the influence vector which represent displacement at nodes due to unit displacement at ground. how do I calculate this when doing modal analysis for free vibration problem.
thanks,
thanks,
RE: mode participation factor
