Force generate surrounding soil during piling
Hello engineers,
I am trying to figure a problem out.Please give me a wise answer .
In cast in situ concrete pile drilling,if the cutter(known as heavy drilling bit ) weight is 1000 kg,then if it fall from above 5',then how much force or how much vibration will generate in surrounding soil?(e.g. near about 3').Also what is this force is known as?Is there any formula to determine this force?
Sorry for my bad english.
here the procedure:
here the procedure:
CODE --> http://www.youtubecutter.com/watch/c00ab8d6/
RIFAT
RE: Force generate surrounding soil during piling
What concerns do you have about the cutter head falling 5' onto the soil?
RIFAT
