Sap2000 base reaction vs joint reaction
thread801-230670: Base Reactions vs. Joint Reactions at the Base
Answer: Response-spectrum base reactions will not match the sum of individual joint reactions because their formulations differ. Base reactions are calculated for each mode before modes are combined using the CQC or SRSS modal-combination rule. Joint reactions, on the other hand, are calculated using modal combinations which are applied to each individual joint.
For example, consider a structural system with four joints and two modes. The SRSS formulation is used. Base and point reactions are generated as follows:
Mode 1:
Point 1 reaction = R(1,1)
Point 2 reaction = R(2,1)
Point 3 reaction = R(3,1)
Point 4 reaction = R(4,1)
Mode 2:
Point 1 reaction = R(1,2)
Point 2 reaction = R(2,2)
Point 3 reaction = R(3,2)
Point 4 reaction = R(4,2)
Base reaction:
Mode 1: SUM mode 1 = R(1,1) + R(2,1) + R(3,1) + R(4,1)
Mode 2: SUM mode 2 = R(1,2) + R(2,2) + R(3,2) + R(4,2)
Base Reaction = √((SUM mode 1)2 + (SUM mode 2)2)
Point reactions:
Point 1 reaction = √(R(1,1)2 + R(1,2)2)
Point 2 reaction = √(R(2,1)2 + R(2,2)2)
Point 3 reaction = √(R(3,1)2 + R(3,2)2)
Point 4 reaction = √(R(4,1)2 + R(4,2)2)
Mode 1:
Mode 2:
Base reaction:
Point reactions:
RE: Sap2000 base reaction vs joint reaction
The previous post suggested an order of magnitude difference which shouldn't be possible.
