Valve type
Valve type
Client specification calls for usage of Ball valve only for Actuated valves for ON-OFF service also for all sizes. Should there be any specific reason for this specification? Contractor proposes to use Butterfly valves.
Thanks to clarify
Thanks to clarify
RE: Valve type
RE: Valve type
Often I see a plug valve as a substitute, I think they are less expensive to manufacture in larger sizes but may require a larger actuator.
RE: Valve type
I agree with UniCO2,that there will be significant cost variation between ball and butterfly valves but is it that the butterfly valves will be less reliable than ball valves in terms of failure of components?
The max upstream pressure of the subject valves is 4bar only.
RE: Valve type
