Wind load on covered pipe bridge
I got a pipe bridge that consists of a couple of 10' x 10' towers supporting what is essentially another 10' x 10' "tower" (running horizontally). Basically the frame is all HSS members. It is very stiff as there are HSS members running between the columns bracing it up. (Almost like a lattice tower except they are connected by welding).
I am uncertain of the wind loading to apply. If it was uncovered with deck.....the answer would obviously be loading it on a member by member basis or per "Signs & Lattice Frameworks" provisions in Figure 29.5-2 in ASCE 7. However, since this thing is completely covered in deck, I'm unsure as to whether to treat is like a enclosed structure, use the provisions in Figure 29.5-1 (i.e. a chimney, tank, or rooftop equipment), or perhaps even treat it like a sign (i.e. the provisions in Figure 29.4-1).
Your thoughts?
Your thoughts?
RE: Wind load on covered pipe bridge
Yep. Except for the ends. (So the pipe can run.)
Good point.
Dik
