How can I design beam which embeded sleeves at mid span and edge of beam?
How can I design beam which embeded sleeves at mid span and joint between beam-column?
RE: How can I design beam which embeded sleeves at mid span and edge of beam?
Is it embedded somewhere besides the supports? Do you want them to act as supports? Or not act as supports?
A sketch attached to your question would help.
