Bearing prelaod and inner ring rotation
Hi everybody,
Does someone have any idea what the preload of a bearing 6204 2rs installed in hub tube with interference fit assembly should be and how it can be measured? We have a customer complaining for inner ring had to rotate "by hand" and we would like to have a criteria or method of measurement to contain the issue.
Thank you very much in advance.
RE: Bearing prelaod and inner ring rotation
You need to call the bearing manufacturer. They can answer this for you in about 10 seconds.
