Hole callout issue, please help
I can't get the hole callout feature to work for a tapped hole on a cylindrical surface. The 1/4-20 hole in the middle view of the attachment was labeled with a Note because I could not get the hole callout feature to work on that hole. Please help.
Thank you,
Trent
NX 9.0.3.4
RE: Hole callout issue, please help
Fixed in NX11.0.1
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Thank you,
Trent
NX 9.0.3.4
Did you try using the ol, Feature Parameter command (example attached) It's worth a try..
SMO (NX10)
