cable tension and end loading
I am building a four post cable railing, approximately 20'x20' square. typical design loading is 250 pounds horizontal at any point..
Using a starting cable tension of 50 pounds, how would i determine an accurate corner post loading if the 250 is exerted on the cable? I've set up a test apparatus, but the numbers are not close to those predicted doing the vector arithmetic..
RE: cable tension and end loading
