Hi CARRIER HAP load calculatio
Hi
CARRIER HAP load calculation shows different heat load for a same roof/wall with same U value but different thickness. Logically more the thickness greater the heat/cooling load
but by the equation of heat transfer for wall/roofs it only depends on the area, U and temp.difference
could anybody explain why?
RE: Hi CARRIER HAP load calculatio
U = t/lambda t: thickness; lambda: thermal condutivity
Q=U*A*deltaT
"CARRIER HAP load calculation shows different heat load for a same roof/wall with same U value but different thickness."
I don't quite understood what you meant whit "same roof/wall".
I'm going to guess that they have the same area, but have different materials.
Is the material the same in both cases?
If they have the same material, makes no sense to change the thickness and U-value stays the same.
Robertogrrmos, you must be right, though the heat transfer equation shows only the area, the U value should depend on the thickness.
I meant same wall that the same area and orientation.
