Points Patterned Along a curve
I have an ellipse sketch.
I placed a point 1" from the end of the curve. This is the pattern leader.
I need 20 points evenly spaced ON the ellipse starting from the pattern leader.
When I pattern the point using the "CURVE" pattern option, the points are laterally offset from the curve by 1". I need them on the curve.
What am I doing wrong? (file attached)
Glenn
RE: Points Patterned Along a curve
Try the Dimension pattern. Creo already knows the point is on the curve and you are only changing the dimension.
I can't open a CREO 3 file but from experience with older versions, you need to make every placement constraint for the point reference the curve to get the pattern to follow the curve.
Glenn,
Don't know if you manage to solve it. If not, divide your ellipse in the sketch so that you can place the first point on that position. Another way is to use "Use alternate origin" under Options in Pattern feature but you will still need a reference point from sketch in that position.
Curve pattern is a bit dodgy. It's quite common that you need to use alternate origin even thoug you referenced your shetch on the start point of the curve.
