NX9 - Sketch - Expressions with Logical
Is this possible in Sketch ?
Example : p10=2 if p3<100 and p4>2
RE: NX9 - Sketch - Expressions with Logical
and second question : validate an Input, I mean, for example p10 can take values only between 1 and 4
Quote (iucu)
In this case, the formula for p10 would be:
CODE
if(p3<100 && p4>2)(2)else(0)
Supply your own value for the "else" case.
Search for "expressions syntax operators" in the help for a full list.
www.nxjournaling.com
I can not find the syntax operators in Help NX
Where is for example If syntax.
Or integer of p1
iucu:
The Expressions section in the NX Docs is here:
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help#uid:index_modeling:expressions_exp_ov
There are links on the right to a bunch of good sub-topics, including Conditional Expressions:
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help#uid:index_modeling:expressions_exp_ov:expressions_exp_syntax_conditional
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
