AS2129 Flange table D and E .ipt files Inventor
Hi there
I'm looking for a library of AS2129 flanges as this is the standard in our region of the world however, Autodesk Inventor did not provide the .ipt material for assemblies.
Have spent half a day searching on Google and could only find AS2129 table F, that's a start however it would be rather practical if I could lay my hands on the table D and E.
If anyone knows where I could eventually find those files, please let me know.
RE: AS2129 Flange table D and E .ipt files Inventor
mk3223 thanks for that but all I can get from your file sharing is only a couple of jpgs no ipt files
You may need to convert these files to .ipt format.
Sorry if I sound retarded but I don't really know a way to convert a *.jpg table into an *.ipt file how do you do this, or maybe you wanted to share a *.sat
Finally will have to work with table E also and found only the blind ones
http://www.3dcontentcentral.com/Search.aspx?arg=AS...
will extrude the bore to make it a slip on however it would be nice if I could find the whole flange AS2129 range somewhere to file it for further use since its not available in the autodesk pack
these are ASME, we are after AS2129
ipt or sat or any library that i can use in 3d modeling
cheers!
Did you even bother to look ?
There are pages and pages of Australian information (including all the charts you requested) after the ASME info.
Sometimes I wonder why I bother trying to help.
DekDee he is after data files that create 3D CAD Models. not printed/pdf information.
