Run of tube points
Run of tube points
hello all,
Can anyone tell what is run of tube ?
And, if "Run of tube B thru H" is defined in the drg, why the points B and H are not defined in the points data table, instead they are defined in the inspection data table.
Thanks in advance !
Thanks in advance !
RE: Run of tube points
Without the drawing we don't know what point B and H is.
What is a points data table?
Not much to go on as could be routing or a manufacturing "run"
What is diameter of tube?
