Switching Between part in NX11
we are having issues switching between parts in NX. The CTRL+Tab does not work. Also using the "Window" to toggle to different parts also does not work. We are using a custom setup so I am thinking it is something in this customization. The Out of the box NX11 CTRl+Tab does work. What area should I be looking into to get this working again? Thoughts? Thanks
RE: Switching Between part in NX11
AFTER UG_WINDOW_CHANGE_PART
BUTTON UG_WINDOW_CHANGE_PART
LABEL &More Parts...
ACTIONS STANDARD
END_OF_AFTER
