AWS D17.1: Tensile strength (minimum) of as-welded 6061-T6 Aluminum
I'm looking for a resource/specification that notes the minimum tensile strength of 6061-T6 aluminum in the as-welded condition should be that of 6061 in the annealed state, since 6061-T6 is known to drop in tensile strength in the weld and HAZ areas significantly following welding. Multiple tensile tests illustrate that values hover just above and below the minimum for 6061-T6, on very high quality welds that pass X-ray to a AWS D17.1, Class A level. This information is needed to assist in procedure qualifications to both AWS D17.1 and AWS D1.2. Additionally, we have experienced bend test failures on 6061-T6 weldments, right in the transition area between the HAZ and unaffected base metal, I believe due to the sharp change in formability from the weld centerline out caused by the welding heat input/annealing. Can anyone comment on this and how it might be addressed going forward?
RE: AWS D17.1: Tensile strength (minimum) of as-welded 6061-T6 Aluminum
Aluminum alloys grouped as M23 and those welded with F23 filler metal must be tested using a bend mandrel much larger than that used for carbon steel. Typically the mandrel measures 2 1/16 inch in diameter for samples 1/8 inch thick. If test thicker material, the face or the root is typically reduced to 1/8 inch prior to bending. Use a wrap around bending fixture to eliminate the problem you mention, i.e., failure in the HAZ.
Best regards - Al
