Assign temperature values to mesh nodes
Hello everybody.
I apologize in advance if this has been asked posted already but I couldn't find anything when I searched about it.
I imported a mesh from another software (Autodesk Moldflow) into ANSYS and now I want to import also the temperature values for each node of the mesh (I have the xml file with the temperature values for each node) and assign them to the one in ANSYS so I can simulate the thermal expansion of the model.
Is there a way to do this?
And if so what should be the xml format?
Thank you a lot for your time and your help.
(By the way I don't know if it is obvious but I am a total beginner to ANSYS :)
RE: Assign temperature values to mesh nodes
For example:
1 100
2 101
After you have to connect External Data to "Setup" block of your thermal analysis.
BF, NODE, TEMP, VALUE
//signed//
Christopher K. Hubley
Mechanical Engineer
GE Aviation
Cincinnati, Ohio
http://engineeringliberty.wordpress.com
@L_K What format should the file for the external data be? I tried with a txt file with the 2 columns like your example but apparenlty this is not the right way to do it.
@flash3780 Do you know how to do it for many values. I have the exported xml file which has the values like this:
<HEADER>
<NAME> Moldflow Simulation Results XML Writer</NAME>
<Version> 1.00</Version>
</HEADER>
<Dataset Name="Temperature, mold (averaged)" ID="5820">
<DataType> NDDT(Node data)</DataType>
<DeptVar Name="Temperature, mold (averaged)" Unit="K"/>
<NumberOfComponents> 1</NumberOfComponents>
<NumberOfIndpVariables> 0</NumberOfIndpVariables>
<Blocks>
<NumberOfBlocks> 1</NumberOfBlocks>
<Block Index="1">
<NumberOfDependentVariables> 93981</NumberOfDependentVariables>
<Data>
<NodeData ID="13229">
<DeptValues> 3.0861e+002</DeptValues>
</NodeData>
<NodeData ID="13265">
<DeptValues> 3.0889e+002</DeptValues>
</NodeData>
</Data>
</Block>
</Blocks>
</Dataset>
</MoldflowXMLDocument>
It is very possible that this technique is not applicable to your analysis yes.
