Want to know the difference between these solution codes....
I want to know about difference between these solution codes in NX Nastran and which one to use in different cases. Guide me to a source where i could find these details.
101 - Linear Static
103 - Modal
105 - Buckling
106 - Non-Linear Static
107 - Direct Complex Eigenvalue
108 - Direct Frequency Response
109 - Direct Transient Response
110 - Modal Complex Eigenvalue
111 - Modal Frequency Response
112 - Modal Transient Response
129 - Nonlinear Transient
144 - Static Aeroelastic Analysis
145 - Flutter / Aeroservoelastic analysis
146 - Dynamic Aeroelastic Analysis
153 - Non-Linear static coupled with heat transfer
159 - Nonlinear Transient coupled with Heat transfer
187 - Dynamic Design Analysis Method
200 - Design Optimization and Sensitivity analysis
400 - Non-Linear Static and Dynamic (implicit) (MSC.NASTRAN native, supersedes 106, 129, 153 and 159 - part of MSC.NASTRAN)
600 - Non-Linear Static and Dynamic (implicit) (front end to MSC.Marc - part of MSC.NASTRAN)
601 - Implicit Non-Linear (ADINA for NX Nastran)
700 - Explicit Non-Linear (LS Dyna plus MSC.Dytran - part of MSC.NASTRAN)
701 - Explicit Non-Linear (ADINA for NX Nastran)
RE: Want to know the difference between these solution codes....
I sincerely hope that you did try looking in the manual before you wrote that question.
Did you ?
https://docs.plm.automation.siemens.com/tdoc/nxnas...
Ps,
There is a little search field in the top of that manual page.
Tomas
