Extracting geometrical set name of point to excel
I have code that exports the name and coordinates of all points in folders that contain the word "STRUCTURE". The part I need now is to also extract the geometrical set name for each of these points which I have not been able to figure out.
Here is an example of what I need:
TEST.CATPart
I then want to export to excel the GeoSet3 geometrical set name to excel for points 1,2,3.
So the data in excel would read as:
Point 1 | x-coord | y-coord | z-coord | GeoSet3
Point 2 | x-coord | y-coord | z-coord | GeoSet3
Point 3 | x-coord | y-coord | z-coord | GeoSet3
Here is the code I have so far:
Sub CATMain()
On Error Resume Next
Dim docPart As Document
Dim myPart As Part
Dim hybBodies As HybridBodies
Dim hybBody As HybridBody
Dim hybShapes As HybridShapes
Dim hybShape As HybridShape
Dim arrXYZ(2)
Dim s As Long
Const Separator As String = ";"
Set docPart = CATIA.ActiveDocument
Set MyWkBnch = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
'If no doc active
If Err.Number <> 0 Then
MsgBox "No Active Document", vbCritical
Exit Sub
End If
'Start Excel
Err.Clear
Set objGEXCELapp = GetObject(, "EXCEL.Application")
Err.Clear
Set objGEXCELapp = CreateObject("EXCEL.Application")
End If
objGEXCELapp.Application.Visible = True
Set objGEXCELwkBks = objGEXCELapp.Application.WorkBooks
Set objGEXCELwkBk = objGEXCELwkBks.Add
Set objGEXCELwkShs = objGEXCELwkBk.Worksheets(1)
Set objGEXCELSh = objGEXCELwkBk.Sheets(1)
objGEXCELSh.cells(1, "A") = "Name"
objGEXCELSh.cells(1, "B") = "X"
objGEXCELSh.cells(1, "C") = "Y"
objGEXCELSh.cells(1, "D") = "Z"
' What do you want to select - in this case a Geometrical Set
'Dim EnableSelectionFor(0)
'EnableSelectionFor(0) = "HybridBody"
' Reset the Selection
Set sSel = CATIA.ActiveDocument.Selection
sSel.Clear
AppActivate ("CATIA V5")
' Define Selection
'MsgBox "Please Select the Geometrical Set where you have the POINTS"
'userselection = sSel.SelectElement2(EnableSelectionFor, "Please select another Geometrical Set", False)
sSel.Search "(Name=*STRUCTURE* & CATPrtSearch.OpenBodyFeature),all"
' Evaluation if the selection is correct or not
'If userselection <> "Normal" Then
' MsgBox "Error with the selection"
' Exit Sub
'Else
' Set oHybridBody = sSel.Item(1).Value
'End If
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "CATPrtSearch.Point,sel"
Dim part1 As Part
Set part1 = partDocument1.Part
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
For s = 1 To selection1.Count
'Set Measure = MyWkBnch.GetMeasurable(selection1.Item(s).Reference)
Set hybShape = selection1.Item(s).Value
Set hybShapes = hybBody.HybridShapes
'MsgBox hybShape.Name 'returns point name
'Extract coordinates
hybShape.GetCoordinates arrXYZ
Set hybridBody1 = hybridBodies1.Item(s).Value
objGEXCELSh.cells(s + 1, "A") = hybShape.Name
objGEXCELSh.cells(s + 1, "B") = arrXYZ(0)
objGEXCELSh.cells(s + 1, "C") = arrXYZ(1)
objGEXCELSh.cells(s + 1, "D") = arrXYZ(2)
objGEXCELSh.cells(s + 1, "E") = Geometrical Set of Point
Next s
objGEXCELSh.columns("A").autofit
objGEXCELSh.columns("E").autofit
AppActivate ("Microsoft Excel")
End Sub
I very much appreciate any help you can provide.
TEST.CATPart
BOB STRUCTURE
GeoSet2
GeoSet3
Point 1
Point 2
Point 3
Sub CATMain()
Dim myPart As Part
Dim arrXYZ(2)
Dim s As Long
'If no doc active
Exit Sub
End If
'Start Excel
Err.Clear
Err.Clear
End If
sSel.Clear
' Define Selection
' Exit Sub
'Else
'End If
Dim part1 As Part
Next s
End Sub
RE: Extracting geometrical set name of point to excel
CODE --> vba
objGEXCELSh.cells(s + 1, "E") = hybShape.Parent.Parent.Name
