Water treatment - Chemical dosing pipeline material
I have specified PVCu pipelines for the chemicals which we are dosing at one of our water treatment sites.
We are providing 3 systems,
1) Polymer
2) Polyaluminium chloride
3) Alum
It has been suggested to me that I should change the material to PE100 (or HDPE) as the pipelines range from 100 metres to 200 metres. The pipelines are installed below ground in covered trenches and also lagged due to temperatures going as low as -10 degrees C during some winter nights.
The hottest is around +50 degrees C.
I would be grateful for your comments. In all the dosing systems I have done I have never actually specified HDPE or PE100.
I guess they may be issues of supporting he pipe but also I'm thinking possible effects of the viscosity. (Only a guess as I don't know for sure)
The polymer dosing will use progressive cavity pumps. The PACL and ALUM will use diaphragm pumps.
Many thanks for your help.
Best Regards
John
1) Polymer
3) Alum
Best Regards
John
RE: Water treatment - Chemical dosing pipeline material
not sure why PE would be thought of as better than PVCu
PE is more flexible and is suitable for burial without any other requirements so maybe more suited compared to PVC to a longer not completely flat burial.
