Y14.41 approach
Y14.41 approach
Does anyone have experience with MBD? Since Y14.41 leaves open the modeling approach, I would like to find out, from your experience, what condition would work "the best" in your particular case.
In other words, what are the advantages and disadvantages to do the model on each of the three conditions shown below?
"4.1 Parts shall be modeled at a specified dimensional condition, for example minimum, maximum, or mean. The dimensional condition shall be specified as a general note."
Did anyone try one condition/approach and then switched to another? (ex. going from mean to maximum or vice versa) If that happened, why you / the company had to switch from one approach to another?
Thank you very much
Thank you very much
RE: Y14.41 approach
I would very, very strongly resist the concept of "min, max, or mean" being the only options for modeling. I believe "NOMINAL" is the most appropriate choice. Nominal might be mean, max, or min. It's the most intuitive and easily understand for precision metals machining of which we mainly focus on. Hopefully when they write "for example minimum, maximum, or mean" they do not mean those are the only three options.
Yes, modeling at "nominal" results in some modeled conditions being outside the actual acceptable range (.5000" shaft size, when the acceptable range is actually .4994-.4998 for a random example) and I don't know anyone in the chain of manufacturing that would find that situation intuitive. It's a 0.5000 (g6) tolerance, by the way. For hardware components... one would buy a 1/2" dowel pin, not a .5002 dowel pin. I also find no benefit to having it to the max/mean/min for CNC programming as all CAM packages I've worked with make it -very- easy to create offsets or path compensation to allow for /intentional/ deviation from the as-modeled condition specifically for situations such as this. I understand it may create a CAD model that does not EXACTLY match acceptable physical condition, but the differences of ten-thousandths of an inch are what I speak of.
I've not run into models from anyone that modeled everything to the max/min/mean only.
Sorry to say, we've not "switched" so I can't comment directly on your final question.
I personally find great benefit in the model "reading" the same as it would if it were a drawing. It's meant to communicate to the reader/viewer/user and to deviate from traditional nomenclature just because it's now a CAD model seems to invite error.
RE: Y14.41 approach
In my experience, nothing works best. It is too dependent on downstream users, spine stiffness in management, and competency of all participants.
Other than that, MBD is based on some weak goals. For some parts the complex geometry, such as for compound curved surfaces, don't lend themselves to conventional 2D depictions and MBD is a way around that. However, I don't recall anything in 14.41 defining a particular round-tripable data format, such that an engineer using software X would produce the same results as another using software Y.
What I do recall from 14.41 is substituting all the work normally done on 2D drawings into whatever proprietary and non-interoperable 3D interfaces that various software vendors might create. So as long as one stays within a software vendor's pipeline it might work or if there are side-channels to make up for the gaps in the MBD.
At one time there was an effort to embed information into STEP models that would allow an automated factory to churn out parts on demand, including understanding the variable geometry allowed for by the embedded tolerance model, but I have never heard anything come of it. At least I haven't seen any CAD modelers use STEP as their native format.
RE: Y14.41 approach
