Finding Stresses AND Factor of Safety Calculations on 3D jig
I had an interview where I had to figure out the FOS at the point where the jig was most likely going fail. Didn't get all the way through the problem and didn't know if if i started out the problem correctly. Could I get some help with working through the problem? The attachment has the information given in the problem that I can remember.
Reuben Huddleston
RE: Finding Stresses AND Factor of Safety Calculations on 3D jig
i've corrected their (maybe intentional) spelling mistake ... its AL not LE.
do they really need 5 decimal places ? maybe for tooling, but ??
that's a lot for an interview calc !
i'd look at the two ends of the inclined flange.
Thanks for responding! No they didn't ask for 5 dec. places that was just my settings in AutoCad
ok, what failure modes did you consider ?
Are you asking in terms of how failure occurred like bending and shearing failure? or failure theories?
failure by bending or shear ... how/where could this fail ?
where would you analyze the structure ?
at point C, do you think 3.75in2 of steel is going to be worried by 60 lbs ? (not sure if that is the sum of the loads or each individual load; not much difference either way) Just like do you see a tension problem with the green area ?
point B or A sure ... there's a subtle difference between the two. The moment at A is clearly higher, but ...
Correct the piece wouldn't actually fail, the main point was to use static failure theories to find the lowest FOS. Having this at an interview I wasn't sure how to proceed with the problem.
I think the logic of the interview question was to see how quickly you could assess the structure, to deduce where the structure is likely to fail.
I suspect section C will have the highest margins, and so therefore not critical. Just like a tension failure in the green web area isn't likely to be critical.
Section A has the higher bending moment, but there's a twist in the calcs that makes it stronger than section B and so it isn't really obvious which is critical.
