Flange Dimensions
Flange Dimensions
Flange Dimensions
Can any one here help me?
I am looking for detailed dimensions for DIN flanges (BS4504) to complete a piping menu for AutoCAD. I don't have access to DIN Standards and the lack of dimensions for DIN flanges is preventing me from completing the blocks for my menu. I would appreciate it if anyone here could help me out.
RE: Flange Dimensions
I can help you there. Give me a week as I am very busy with work at present.
Cheers, Steve.
Thanks SteveMS, I'm not in a rush so don't overwork yourself for me.
Thanks Isthill, that site helped a bit.
Hi paddymac (Mechanical)
You need to read the follow from the HOME OF COMPRESS:
http://codeware.com/papers.html
These historic papers in pressure vessel design are offered for your information:
• "A Proposed Method for Finding Stress and Allowable Pressure in Cylinders with Radial Nozzles," PVP Vol. 399
• The L P Zick paper for horizontal vessels on saddles
• The Boardman paper on cone-to-cylinder juncture stresses
• "Vibrations of Vertical Pressure Vessels" by C E Freese
• "The Design of Vertical Pressure Vessels Subjected to Applied Forces" by E O Bergman
• "Evaluation of Percent Critical Damping of Process Towers" by Karamchandani, Gupta, and Pattbiraman
• "Stresses in a Pressure Vessel With a Conical Head" by G W Watts and H A Lang
All papers are self-expanding zipped or Adobe pdf files.
Leoanrd@thill.biz
www.thill.biz
Thanks for those links Isthill but they're a bit outside of my needs and understanding.
SteveMS, any progress or news from you
Paddymac - Still need BS4504?
I'm still looking for the BS4504 dimensions TerryOsser. If you can provide me with them or even some of them I would greatly appreciate it.
Paddymac, I have been very busy, I'm sorry. email me at cb34gs@paradise.net.nz and I can send you a heap of info on flange dimensions.
Steve.
Thanks for that grandnobi.  I actually found that myself a few weeks ago after I had all the info I needed.  All I need now are dimensions for BS flanges (Table D, E, etc) to complete the set.
I have a pdf file with tables A to J.
Also I have K,R,S,& T if you need them.
Cheers
George
Thanks George, can you email the pdf to me.
pmackey@eircom.net
Much appreciated.
Paddy
