Shock Response Spectrum (SRS)
I would appreciate some help regarding analysis of SRS in MSC/NASTRAN. I have generated a SRS from a (close to) a half sine shock in the time domain, and want to use this as an input in MSC/NASTRAN sol 103. What about the damping? I alredy defined a damping when generated the SRS (The SRS was not generated in NASTRAN). Should I define a damping again when running the SRS sol 103 analysis?
Any useful hints would be appreciated.
RE: Shock Response Spectrum (SRS)
Now you also can define modal damping function correspondent to your system.
