Help with transparent food-grade tubular system and 3D parts
hello, this is the problem to solve:
I need a transparent food-grade PVC tubular system joined with "U" and "T" with more similar tubes, but also joined with custom 3D printer parts.
How to make this circuit?
Discussion is: should I use (A) mechanical joints or (B) PVC paste?
- I should use a tubular size of 50 or 63, since these are standard sizes compatible for the "U" and "T"
- I think there is no food-grade paste for PVC, should I go for A then?
- What 3D printer material to use to paste PVC with? and what paste?
Do you have any better ideas or suggestions? would you go for A or B then?
Thanks in advance
Thanks in advance
RE: Help with transparent food-grade tubular system and 3D parts
Mike Halloran
Pembroke Pines, FL, USA
Dan - Owner
http://www.Hi-TecDesigns.com
there are food-grade transparent PVC tubes:
- http://tecno-products.com/producto/pvc-cristal/
- http://www.mwmaterialsworld.com/es/tubo-rigido-de-...
and with 3D parts, you can use a 100% density, that should avoid liquid to pass through
anyways, dont you think guys I should assemble the PVC or other similar material with heat instead of using non-food-grade pastes or mechanical joints?
Dan - Owner
a silicone food-grade flexible transparent tube and clamps, difficult to find here thought, since I only need 2ms and they can order only rolls of 20ms
