Geared motor selection help
Hi all,
I need help with finding companies that manufacture small hi-torque, worm geared motors (something like this the 12VDC 56 Kg.cm stall torque model).
I can't use trading sites (ebay, aliexpress etc.) because i need an official manufacturer that ensures quality and support, but so far every manufacturer i found has only planetary geared motors and the worm geared ones are to large or to week for the application i need them for.
Needed motor specs:
1. Voltage 12VDC
2. Stall torque 5-8 Nm
3. Speed 3-10 RPM
4. Worm geared
5. External/internal threaded shaft + key slot/D shaped shaft
6. Miniature size
Thanks.
Needed motor specs:
1. Voltage 12VDC
3. Speed 3-10 RPM
4. Worm geared
6. Miniature size
Thanks.
RE: Geared motor selection help
http://www.electricmotorwarehouse.com/dc-gear-moto...
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
But i did search for motors before asking here, the thing is that for some reason the majority of the results that google provides are from ebay, aliexpress and the likes (sites i didn't even know existed) and the results that are relevant, there are no suitable motor on those sites.
You might want to check Crouzet ,Bison and Pittman (Ametek).
Kyle
http://www.thomasnet.com/
Oriental Motor
Maxon
Portescap
Thank you all!
Now just go to http://www.thomasnet.com/. You can filter by manufacturer, distributor, whatever. I don't think you'll find the Alibaba's or Ebay there.
