RAM Concept - Mat Foundations
Hey guys, this might be a bad question, but I really want to know this. So recently I designed a raft foundation with column drop panels, my superior suggested to merge the column drop panel to become a column strip so that the overall depth of the "merged drop panel" strip can be shallower. So then now I want to design the column strip in RAM Concept, but I've used the drop cap, and make it to a really long drop cap, but the analysis failed. Anybody can give a lesson or two? Thanks.
P/s : I need to know the new depth for the column strip.
RE: RAM Concept - Mat Foundations
Thanks! :)
Best regards,
-TR
Alternatively, you could design the slab for constant thickness and provide shear reinforcement for the punching shear where required. It will simplify construction for your main rebar layers, and have a constant site prep, which should be able to justify the punching shear reinforcement.
@SethGuthrie : Thanks, I will have a look at it.
