Extension spinndle
Extension spinndle
Extension spinndle
Dears ,
What is the different between Hollow , rigid & telescope extension spindles for the valves applications ?
Ahmad
RE: Extension spinndle
Self explanatory. The use of either of these will depend on the application and what materials of construction are used, the strength of the spindle required, the corrosion resistance required, the operating torque required, and the spindle length required.
