Flexural test for a Sandwich ( ASTM 393 )
Hi Guys!
I want to do a flexural test for a sandwich ( ASTM 393 )
According to the standard the lenght of the specimen must be 150 mm .
My specimen is unfortunately only 130 mn long
Is there any solution ?
thanks
thanks
RE: Flexural test for a Sandwich ( ASTM 393 )
C393 is intended for core shear failure modes
D7249 is intended for face sheet failure modes
If you want core shear, the shorter 130mm specimen will probably work fine. But it also depends on the core depth and material properties.
I will investigate the Stiffness and failure behaviour of Sandwich
