NX 11 Drafting Baloon Type
Is there a way to define balloon type in a drawing template? For example instead of a circle to be Type - Underlined, Stub length = 0 ... and without needing to define these specs each time you start using balloons. In Customer Defaults -> Drafting -> General/Setup -> Drafting Standard -> Customize Standard -> Balloon, it appears that you can only define circle diameter and line thickness but not balloon TYPE. Same thing in Drafting Preferences -> Annotation -> Balloon, no type option.
RE: NX 11 Drafting Baloon Type
www.nxjournaling.com
