sewer profile
sewer profile
what is the benefit of sewer network profile and when we should make it ?
RE: sewer profile
Mike Halloran
Pembroke Pines, FL, USA
RE: sewer profile
I've seen very few utility plans that don't include them, so for site/civil work I'd say it's a must have. For inside a building, I've occosionally put one togther for my use to coordinate with structural foundations, even more rare is to include on a building's plumbing plan. Most useful here when sanitary needs to be run shallow.
RE: sewer profile
Thank you for your reply. in my opinion we can make sections for the purpose of coordination.
i used to make the sewer network and manhole profiles with infrastructure for big projects and streets to show the ground level and manhole invert level ,
but what i'm asking about is that we have to make profile for the sewer network around one building or no need?
RE: sewer profile
1. The are one dimensional, whereas profiles "flatten" the piping into one dimension - so they can "follow" the entire length of piping.
2. Often the scale on profiles are not the same in the x/y direction. The y dimension is typically less than 10-20 feet, but the x dimension can be 100's of feet. So unless you make a section which takes that into consideration, you would have a long section on the drawing.
