Discontinuous Cross-Section Moment of Intertia Calculation
Hi All,
I have a design that I'm trying to analyze by hand calcs before I use numerical methods (FEA). I'm working on beam calculations for max shear/moment so that I have something to validate against an FEA result. The design involves applying pressure to two flat plates that are joined to and separated by bars (see picture attached). The intended design is locate the bars such that the two plates act as a composite beam (which is a totally different discussion unto itself).
The place I'm running into trouble is in the calculation of the moment of inertia. I was trying to think of this design as a series of I-beams with the edges of the flanges welded together. Based on the orientation of the bars in relation to the load, I'm assuming the bars (ie. the web of the I-beams) won't add much, if any, stiffness to counteract the bending moment. Similar to an I-beam, all of the bending stiffness will come from the two flat plates (ie. the flanges of the I-beams). However, this is just my assumption.
It's easy to ignore the bars, calculate I based on two flat plates acting as a composite beam and say that is a conservative approach. However, I would like to see how much the value for I changes if the bars are included in I. The issue is, I can't figure out how to calculate I for a beam with a discontinuous cross-section. Can any one provide some guidance on how to do this? Is there another way to look at this setup to make calculating I easier?
Thanks in advance for the help!
-Steris
-Steris
RE: Discontinuous Cross-Section Moment of Intertia Calculation
For design purposes, you could make some checks and assumptions on the spacers and shear through them, buckling of the unsupported web, etc. But those aren't necessarily going to be very close to the stresses calculated from a finite element approach.
Keep in mind that in normal beam design assumptions, you're analyzing stress away from the supports.
For example, in your upper diagram, all of the shear has to be carried by the flanges at the support, which is exactly opposite the distribution assumed in a beam. If this is actually a rectangular plate supported on 4 edges, etc., then the difference may be considerable.
Jstephen alludes to this, but I’ll say it more directly, you will have a far more efficient and traditional bending structural system if you reorient the web elements 90̊ in plan, so that they span from reaction point (line) to reaction point and work with the t&b plates (skins) as part of the bending system. Then, you will be able to calc. a meaningful moment of inertia, etc. and the two t&b plates will take most of the bending forces/stresses and the webs will take most of the shear/shear stress at the reactions, where these are the greatest. The way you have the top sketch detailed right now, the bending strength will be pretty much dependent upon the t&b plates, with a deflected shape which has fairly straight line/flat sloped shape btwn. each of the ribs and a fairly concentrated rotations at each of the ribs. It is a stretch, but your top sketch will act kinda like a Vierendeel truss structure, depending upon how you detail it.
why orient the webs that way ? for convenience in welding ?
as noted above the other way (spanning across the supports) is a much more natural way to carry the shear load.
To clarify, the top diagram is a cross-section of the design with the span running into the page.
-handleman, CSWP (The new, easy test)
A For the purpose of this analysis, no it is not.
ok then, how will it react shear ? through membrane loads in the caps ?? transverse shear in the caps ??
sure your hand calc shows that the caps can handle the moment; but what's the shear loadpath ?
how much did the FEM deflect ?
how did you constrain the caps in the FEM ? rigid constraint on both sides, both caps ?
