Radiography Requirements
Hi Everyone,
I have one query regarding radiography marking on ASME U stamped vessels.
As per client requirement Category A (Long seam) & Category B (Cir seam) of shell must be spot radiographed, i.e E =0.85.
But Category A joint of dish with seams must be fully radiographed, i.e E =1.
Kindly advise what will be the marking to be stamped on nameplate.
Balaji Rai
RE: Radiography Requirements
RT-1 doesn't fit, since the Cat. A of shell is not fully Radiographed.
RT-2 doesn't fit, since the Cat. A of shell is not fully Radiographed.
RT-3 doesn't fit, since Cat. A of head is fully Radiographed.
That leaves you with RT-4.
Hi David,
Thanks for your reply.
Balaji
If you actually have a head seam...
