Design criteria for shaft frame
Refering thread507-378923: Design Criteria for Glass Elevator Shaft Frame
Dear gents,
I am very new to the world of structural engineering and i got a 3 story elevator shaft work. (steel framed shaft with point supported glass paneling).
I cant find any relevant code for elevator shaft and i dont know much about the loads coming on the frame from elevator cab.
1) What all loads will act on the steel frame and also on the glass? Mainly my confusion is regarding the load coming from the elevator cab. what will be the load coming and what will be the nature of loading. (The concept of How the load transfer from elevator car to steel frame)
2) What will be the deflection limit for the steel as well as glass?
Please please help me on above things. Thanks in advance.
Shafeeh k
Dear gents,
Shafeeh k
RE: Design criteria for shaft frame
*The lifting method is hydraulic lifting
*Only supported on the ground floor slab
If hydraulic, then load is at the bottom and shaft takes care of braking forces and any lateral loading.
Should have elev mechanical room in close proximity to the elevator.
Should talk to the elevator supplier (I usually spec one, with app'd alt).
Dik
