Rebar Welding
Rebar Welding
I have some questions about the welding electrode.
When I weld A706, Gr 60 rebar to A36 bearing plate, I think I can use E70 electrode.
If I replace the bearing plate with A706 rebar, should I use E80 to weld rebars according to AWS1.4 Table 5.1?
Is there any way to use E70 electrode like increasing welding size?
I am looking forward to your input!
Thanks!
RE: Rebar Welding
Dik
RE: Rebar Welding
RE: Rebar Welding
Dik
