Studio surface "Split curves output along boundary curves does not support this configuration&q
Hi there, I^m having this problem with the studio surface comand.
"Split curves output along boundary curves does not support this configuration"
This mesagge pops up when I^m trying to execute the command.
I want to make this surface, and must be g2 at least in the boundaries.
Any help please.
Thanks in advance.
Any help please.
Thanks in advance.
RE: Studio surface "Split curves output along boundary curves does not support this configuration&q
The "hole" to the left looks like it has G0 curves in the boundary.
The Studio Surface will probably not accept that . That corner would probably produce a G0/C0 seam in the surface.
The Curve Mesh will probably accept this. It will use the modeling tolerance to "soften" that sharp corner.
Tomas
