Surveying - measure vertical displacements
I'm working on a project and have to measure the vertical displacements of a beam. I am wondering if there are any surveying tools I can use to measure vertical deflections of 0.01 inches? Could someone recommend tool to use?
RE: Surveying - measure vertical displacements
Dik
> There are lots of laser distance measurement systems with micron-level range resolutions. An extension of those are the 3D scanners: https://www.creaform3d.com/en/metrology-solutions/...
TTFN (ta ta for now)
What is your "anchor" point, and how will you verify IT has not moved under the load that deflected the beam?
Example: Your deflected is horizontal, 20 feet long. You attach the "anchor" to the vertical column nearby, then apply the load to the horizontal beam. The load deforms the vertical beam as well, and your "measurement" is "zero" - Because the vertical beam twisted the measurement lever arm down just as far as the beam deflected down under the load.
Dik
