Design Sec.VIII div.2 vessel using a material not listed in Sec.II
I am designing a vessel for div.2 using material Q345R. On searching about it, I found that this material is most similar to SA515.Gr.60.
The material has higher minimum yield and tensile strengths than SA-516.Gr.70. On going through a similar question in thread794-349081: Allowable stress for non standard material (ASME section 8 Div-2), I got to know that materials unlisted in section II-D are not allowed to design div.2 vessels. But no code references were mentioned in that thread.
Please help me to have some clarity on this with relevant code references. Also it would be very helpful if anyone could send me the allowable stress table for this material.
Thanks a lot,
Vishnu.
Thanks a lot,
Vishnu.
RE: Design Sec.VIII div.2 vessel using a material not listed in Sec.II
Have you actually opened up the current version of the Code? Have you read it? I'll point you in the direction of Part 3, but you will need to do the actual reading and comprehension yourself.
At some point, designing to a pressure vessel Code requires some level of competence, and that competence starts with reading the book itself.
You are welcome to return here with a specific paragraph reference to confirm your understanding, but no one here is going to do your work for you.
Thank you very much for your reply. I humbly beg your pardon for my stupid question. Our competitors from another country have been selling div2 vessels (without U2 stamp) using this material. That's when my marketing officials asked me if this is possible. I did go through div2 part 3. 3.2.1.1 and 3.2.1.5 clearly states that it is impossible, but the clause " unless specifically allowed by other rules of this division" at the end of 3.2.1.1 made me doubt whether there could be a rule which allows this. When no one could answer this query of mine, That's when I decided to put the question here. I agree that I am incompetent and inexperienced with div2, but I don't want to let go of a chance to learn it.
Once again, I am extremely sorry for my dumb question, but thank you ever so much for your valuable reply
Vishnu.
Please inform your marketing people that you have far too much integrity to be associated with anything of this sort. Unlisted materials are forbidden; full stop.
Btw, your follow-up reply demonstrates to me that you are much more knowledgeable and competent than your original post. Good luck!
