Double click Text or a block w/ attributes.
3
I have A2K
About a year ago I had a routine that would allow the user to double click text or a block with attributes and then would show the appropriate edit dialog box. Does anyone know of this routine, send me a copy, or know where I can get again?
Thanks for your effort in helping me!!
Charles S. Parnell
Southern Store Fixtures
RE: Double click Text or a block w/ attributes.
What happens now when you double click the text or attribute in A2K?
Check that DBLCLKEDIT = on
Cheers
Mike
Nothing. I checked my help file for System Variables, there is no listing for DBLCLKEDIT in A2K.
This is what I got at my command line.
Command: dblclkedit
Unknown command "DBLCLKEDIT".  Press F1 for help.
Do you have any other ideas?
Thanks for your help!!
Charles S. Parnell
DBLCLKEDIT = on is a system variable from A2k2
Not the solution you had but you could, click on the block, then if you have a keyboard shortcut like A or shift-A (for attedit), you could set up a quick attribute edit. Or you could add it to your right-click menu. Just some thoughts.
OK then try this one
set PICKFIRST = 1
If that doesn't work I have got one more drastic measure.
Cheers
Mike
o.k., i have dblclk = on and pickfirst = 1, but still my double click edit only seems to work at random times? any suggestions?
