bearing inclination
bearing inclination
Hi.
I am currently building a rotating machine with a shaft that's 1.500mm long (aprox. 5ft), with a diameter of 280mm.
It has a 10º inclination.
Due to the vibaration of the machine, I chose the SNL3156 housing and the 23156 bearing to support vibration, rotation, and the inclination of the structure.
Can anyone please tell me that this is the right choice? Or if there is a better one?
Thank you.
Thank you.
RE: bearing inclination
You mentioned the bearing model numbers but left out the brand name.
I would suggest you contact an application engineer at the bearing manufacturer for your question.
http://www.skf.com/group/products/bearings-units-h...
shaft speed (variable?)
Axial/thrust load
Radial load
Hollow shaft?
Drive coupling?
Vibration source (dynamic force and frequency)
Walt
