Automatic definition of beam element cross-section orientation and normal?
When I allocate beam elements in a 3D model, Abaqus asks me to define the cross-section orientation (and normal?). I have a lot of elements, so I'm looking for an efficient way to define the direction. My beam cross-section is circular, so the direction doesn't really matter. Is there a way to automatically set the direction, for example based on the start/end points of the struts? I also want to avoid looping through every element and calculating it, as it takes a lot of time. If I don't assign it, I get the error
The number of elements (XXX and YYY) is smaller than the total number of elements, so it seems to work for some. Also, I'm using Python.
Thanks a lot for your help!
CODE -->
Error in job job-manual_block: Error in defining or computing beam section normal in XXX elements. The elements have been identified in element set ErrElemBeamSecNormal. Error in job job-manual_block: The beam cross-section direction vectors coincide at a node in YYY elements. The elements have been identified in element set ErrElemBeamSecDirVect.
RE: Automatic definition of beam element cross-section orientation and normal?
