Div. 1 Impact Testing
For Section VIII, Div. 1.
I've always seen two sets of weld metal specimens (cap and one at 1/4t), so I never thought to look this up. I'm having a very difficult time finding in the Code where it tells you how many weld metal specimens (not HAZ) are required for production impact testing. If someone could point me in the right direction, I'd really appreciate it
Thanks in advance!
RE: Div. 1 Impact Testing
Check out UG-84 (i)(2) - "Test shall be made of the weld metal and/or heat affected zone to the extent required by the procedure test".
