Rounding drawing dimensions to 10mm or 100mm in NX10
I have small issue with drawings that show, for example 32034 mm, this 34 mm are some o-rings and shims, and we would like to make this drawing so it shows rounded information of 32000 mm. I personally do not want to edit and replace dimension with text, so I am looking if it is possible to round dimensions by using options that will keep it "alive".
I searched the forum and I saw this thread.
http://www.eng-tips.com/viewthread.cfm?qid=319311
Just want to know if this is still true or there is new solution for NX10 for rounding to tens or hundreds of mm in drawings.
_____________________________
Enjoy your work and have fun!
