Step by step material transfer through a die
Hello everybody,
I need an idea in how to design a feeding system for a die press. The material comes in sheets.
Is there any way to use the pressing stroke to index - feed the material through the die set.
What are the most reliable transfer systems?
Thank You
Thank You
RE: Step by step material transfer through a die
