NX routing in manage mode >> setup
Hi -
Just a stort question...
Can someone confirm , that the PTB & PLV files shall be uploaded in a specific dataset in teamcenter , if routing standard parts is located in teamcenter as well....
And afterwards some environment variables should point to these item's, which contains the datasets with PTB & PLB files....
Regards lklo....
Regards lklo....
RE: NX routing in manage mode >> setup
CODE --> ugii_env.dat
UGII_ROUTE_MECH_KIT_DIR=##Your Server Location## UGII_EPLIB_PART_LIB_VIEW_PATH=${UGII_ROUTE_MECH_KIT_DIR}\appview UGII_ROUTE_MECH_APP_VIEW=${UGII_ROUTE_MECH_KIT_DIR}\appview\ugroute_mech_metric.xml UGII_EPLIB_TABLE_PATH=${UGII_ROUTE_MECH_KIT_DIR}\metric\tables UGII_ROUTE_MECH_PART_PATH=${UGII_ROUTE_MECH_KIT_DIR}\metric\parts UGII_ROUTE_BEND_TABLES_PATH=${UGII_ROUTE_MECH_KIT_DIR}\metric\tablesRonald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
thank you very much...
I just tried today - and it works very well in manage mode, as well...
Though, I faced some issues regarding the attributes from part family' member into the PTB file...
Not sure which exactly attributes should be part of the PTB files - but I will play with some different combinations.
