Shaft run-out check
Shaft run-out check
Hi guys, During the run-out check of a pump shaft, how important is it to make sure that the two V-blocks are vertically at the same level. In other words, the shaft being check for run-out is perfectly horizontal.
Thanks.
Thanks.
