Heat exchanger :Air Cooler
Hello guys ,
I'm working on a thesis on Air cooling installation in a refinery , i would like to have some information about the topic (books, article , publication) in English, French, Romanian and Spanish . I found a lot of Informations about this kind of heat exchanger but nothing specifically applied in oil and gas industry (refinery plant) . I would be really glad if someone could help me .
Thank you very Much.
RE: Heat exchanger :Air Cooler
How about API 661 Petroleum, Petrochemical, and Natural Gas Industries—Air-cooled Heat Exchangers
Good basic information here:
https://www.geoilandgas.com/sites/geog.dev.local/f...
I would emphasize how these HXs must be of robust construction for demanding oil & gas service.
I would also mention how the engineering need to mount these HXs high in the plant means that they must be considered early in the design process and will often control the design of the main pipe rack.
Please share your final product with us .....
MJCronin
Sr. Process Engineer
Also in the GPSA and in Perry Chem Engg Handbook. Air coolers must be installed with the cooler deck at least 25ft above a grade where hydrocarbon liquid pools could collect. Also know how to select between forced draft and induced draft options. Cooling duty turndown requirements may necessitate options such as VFD fans for some applications and winterizing in some colder climate locations. Get an experienced materials selection engineer to assist with materials of construction for tubes, fins and header boxes.
