metallurgy recommended for electro polishing?
Dear All,
What is the best stainless steel wire for electropolishing ?
Is chemical composition of base metal affects electro polishing ?
RE: metallurgy recommended for electro polishing?
You want to EP the wire?
Composition, microstructure (and cleanliness), and surface finish are all factors.
Contact a company that specializes in the electrolytes used for EP.
Insufficient information and cryptic post invites low traffic. Also, try and participate in discussions, it will help you structure your post well.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
